Best "reasonable" cartridge for pro-ject debut lll
Username: Malco49
Baltimore, Maryland Usa
Post Number: 74
as subject says looking to upgrade from cartridge that came with my turntable,since i have had it for going on two years,and would like to upgrade.so looking for best "reasonable" upgrade for this TT
thanks
malco
Username: Artk
Albany, Oregon USA
Post Number: 4680
Depends on what sound you're looking for. Grado Prestige Black or Blue are very good budget cartridges that give good detail and are forgiving. They should work with your table and arm.
Really must know what you are playing and what sound you are lookin for though.
Username: Malco49
Post Number: 75
generally play my old vinyl/some newer 180gram.
it would consist of rock and roll and some jazz.
records in mint to very good condition.
thanks for the comment art.
Username: Artk
Albany, Oregon USA
Post Number: 4687
With that in mind I would stick with my recommendation.
Username: Jan_b_vigne
Dallas, TX
Post Number: 10371
What cartridge came with your table and why do you think you want to change? Describe the sound you have along with your other gear and tell us what is good and bad about your current system. Please, do not say "there's nothing wrong with what I have". If there's nothing improper about what you own, why change anything? Do you just have some money to spend? How much?
Username: Malco49
Post Number: 77
sage advise jan.
