Subwoofer placement issue...
Username: Ccdoggy
Post Number: 112
So i finally finished my LLT FI Q 15" driver with an EP2500 powering it. I will be moving into an "apartment" and need to figure out how to setup all my sound gear in my room.
I basically have 2 options, The first being something i think might work, and one that will work.
1st option is to do the usual thing and put it in the front left corner, pretty safe and generic place to put a sub.
2nd option which would make my life allot easier would be to put the sub in the middle of the wall and have the center channel actually be on top of the Sub with the left and right fronts next to the sub. This would help allot as i dont know how much room i have to work with and the sub takes allot of space, with it in the middle i could have the AV rack on the right side or really where ever i wanted.
The problem i see with the 2nd option is mainly the response. The room is a rectangle but i have no clue what the actual dimensions are.
Do you for see any real problems by center locating the sub? would it really be that bad?
Thanks for all the help!
Username: Jan_b_vigne
Dallas, TX
Post Number: 10342
I assume you haven't read any set up guides for subwoofers.
Username: Ccdoggy
Post Number: 113
well i have, the issue is room and having the sub in the middle.
The sub is not small by any measure, its 12 cubic feet. There in lies the problem.
Dallas, TX
Post Number: 10345
I would assume the issue would be where does the sub work best, regardless of size. It would appear you are asking for our permission to place the sub in the middle. Center placement of a sub is seldom the best location. And placing another speaker on top of the sub is usually to be avoided. What exactly are you asking?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 73
Placing your center on top of your sub probably would not be such a good idea. Just thinking how much my subs vibrate... I'm sure there are all sorts of sonic issues involved with this as well.
Username: Ccdoggy
Post Number: 118
I suppose the sub vibrations would make their way to the center channel's woofers which is definetly not optimal.
I am more or less asking if i will be alright with the response i will get with the sub in the middle compared to the corner. is it still going to sound good, or will it need a good amount of equalization?
Username: Davidpa
Portland, Oregon US
Post Number: 465
Trial and error with the sub placement,
unless you have 2 subs (both centered opposite each other), the center position will generally not net the best results, but I have seen odder things.
There is no set in stone answer here, you need to experiment, which is what I think Jan was hinting at.
Dallas, TX
Post Number: 10351
I was trying to say we can't tell you much about how a subwoofer will sound in one location or another when we have no more information to go on other than what has been provided, which doesn't even include the room dimensions. Placing a subwoofer along the centerline of any room will normally excite the most room problems and do so with more symmetry than a corner placement would manage. Unless you don't care how the subwoofer sounds, I would not suggest you consider placing it in the center between the two speakers. However, with no more information to go on, I would say "suck it and see what comes out". It seems ridiculous that you would spend time asking rather than just trying the various positions when you move in. If the sound is OK with the sub in the center and you find no other position that sounds better, then the center will do. Do you want me to tell you which drawer to put the silverware in?
Username: Alright_boy
Post Number: 217
There he goes again with that condescending bull.And you guys actually worship him. What a shame.
Dallas, TX
Post Number: 10355
Shame? I'll tell you what a shame is. That you are taking oxygen away from the rest of us.
All hat, no cattle.
FOJBJ.
Username: Arande2
Just a matte... Missouri
Post Number: 2403
Farewell, goodbye, although I'll cry
Ain't that a shame?
My tears fell like rain
Ain't that a shame?
You're the one to blame!
Dallas, TX
Post Number: 10357
What Andre said!
Username: Stu_pitt
Irvington, New York USA
Post Number: 1815
Steve,
An effective - but not foolproof - way to place a sub would be to start with the sub at your listening position. Put the sub where your seat is, and walk around the room. Where the bass sounds best in is where to put the sub. Sit in your seat and listen. Then move it around to see if anything improves.
If this doesn't work well, back to square one.
Username: Ccdoggy
Post Number: 120
Thanks for the suggestion Stu.
any one have an opinion about placing the sub behind the listeners. Its mainly for movies and what not.
Dallas, TX
Post Number: 10361
Don't.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 2020
Dr. Hsu recommends it. Having the sub close to you will certainly allow you to dial it down with the same volume in your seat. That could help with neighbours if that's an issue.
Dallas, TX
Post Number: 10362
And it might work well in this application. How can we guess? All we know is SH has a big subwoofer that he wants to put in a small room. With only that much information to go on, how are we to answer anything? But, if SH's sub doesn't have a phase compensation control, placing the sub behind him is less likely than most other positions to garner the best results. Unless he has one of Dr. Hsu's subwoofers, that is.
Username: Thx_3417
Bournemouth ...
Post Number: 3724
Let's have a long story short ok.
Note the professional cinema THX set-up and how the loudspeakers are positioned into the THX baffle wall and WOW look at that cluster array of JBL 4645C in the centre bottom part of the screen and placed above it is the JBL custom array yes centre yes this is how its done now JUST DO IT!
Username: Nuck
Post Number: 7174
How did the picture of my basement get out here?
Post Number: 2021
Didn't picture you as a JBL kinda guy Nuck.
Username: Artk
Albany, Oregon USA
Post Number: 4684
That's actually a picture of his family van...and I thought things were bigger in Texas.
