Bronze Member Username: Josh1005Norfolk, VA U.S.A Post Number: 95 Registered: Mar-07 | what do you guys think about the new recievers do you think it is really neccisary to go and spend hundreds of dollars to replace perfectly good reciever jto upgrade from 1.1 to 1.3 HDMI or will my onkyo 804 translate HD audio good enough?? |
Gold Member Username: KanoBC Canada Post Number: 1183 Registered: Oct-04 | http://www.avsforum.com/avs-vb/showthread.php?t=789994 |
