Bronze Member Username: BunnyBig D, Texas Post Number: 51 Registered: May-05 | Hello all, Can someone please assist me to understand what "THD" means? I found the definition on expedia: http://en.wikipedia.org/wiki/Total_harmonic_distortion#Explanation but I would like to understand it in pure basic English (THD for Dummies) ![]() How this affects the sound or does it? The THD on some tubes is less than 1% whilst others are rated at =< 2%. I want to pull the plug on a tube integrated but before I do I would like to understand this concept. Thank you very much in advance |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10257 Registered: May-04 | . http://eli47.tripod.com/audiogloss.html#t-u |
Bronze Member Username: BunnyBig D, Texas Post Number: 52 Registered: May-05 | Thank you |
