Hi, was wondering if someone could help me with my problem . My Amp lost almost all the volume today , it was switched to the tuner , when i switch it on it would only produce an output through the speakers if i put it all the way into +db's , only then i got only a whisper, only when i put it on source direct i get normal output ( normaly ~ -45db) listening volume. i tried a CD - same issue. i connect a different set of speakers ( i only run it for music with 2 speakers) i get normal (-45db) output volume for a minute or so then it cuts out and only delivers if i put it back on source direct. i tried different size speakers (bose 302s , jamo e650) allways the same, i get ~ 1 minute in other then source direct mode , the -silence, put it on source direct it's fine.
Any ideas , the amp has never been trashed , i just can't work it out.
