Hi guys, I just got an X-Fi Platinum for my computer, and i want to create a "makeshift" 5.1 system using what I alreay have. Currently, I have my stereo hooked up as my rear speakers, and a 2.1 system hooked up as my front speakers. (Both are via the 1/8" mini plugs on the back of the X-Fi). I'm looking to buy a center channel speaker, and I've been eyeing the Infinity Primus C25; My question though is since I assume it uses speaker wire for connetion, can I buy a speaker wire->RCA Cable, then RCA->Mini jack and hook it up to the soundcard in the center channel jack? Or do I need an amplifier or something.... thanks.
Andrew, I run the same card, but have no rear side access from inside the case. I run streo from the headphone out on the front. Are you using the remote I/O unit via the midi port?
Andrew, if you use the line level outputs from the I/O card, you can add a 5 channel amplifier directly. Like, say, a Rotel rmb985 amp. The card and software are very good.
Is the amp necessary though, or will I be able to just directly hook up this new speaker to the soundcard if I buy converter wires? $1000 for the amp is a lot for me....
Btw, I'm somewhat of a noob when it comes to audio so please bear with me. thanks.
I'm using the outputs on the back of the card, in the back of my computer, not the I/O front bay. Right now I'm using the rear and front output jacks, so couldn't I just hook up the center speaker to the center jack without an amp? I'm asking this because I'm on a tight budget and would prefer to not have to buy an amp. thanks.
I see what you're saying. I'll definitely get an amp when I can afford it, but going off to college in a year, I don't have the money to buy a nice amp. I can't wait until I have a nice job and steady income so I can buy some nice equipment. Thanks for all of your advice though, I'll definitely keep it in mind for when I can afford an amp.
Andrew, a receiver will suffiece and get you on your way. After so many years and mistakes along the way, I forget the days of KD and chicken weiners, I guess.Had lots of those! A receiver with 5 ch inputs will get you on the go. Heck,a 2 ch receiver will get you running, I still like H/K.
