AVR 245 Troubleshooting
Username: Tc_skier
Post Number: 153
Just got an HK AVR 245. I've currently got it hooked up just in stereo mode to some brand new wharfedale 9.2's which are 6 ohm speakers. As I push the volume up to about -16 db, the receiver goes into protect mode.
Do the speakers need to be 8 ohm or is there something else I need to look into? The unit is a refurb bought directly from HK through their eBay store. Is it possible the problem wasn't fully fixed?
I paid $330 for it so if this is gonna be a lasting problem I'll be more than happy to return it and pick up a 3480 brand new for $225. That one I know for sure will handle 6 ohm speakers...it's rated 150 watts at 4 ohms and 120 at 8 ohms so 6 ohms wouldn't be a problem for it if that's the culprit. Replies needed ASAP, thanks for the help!
Username: Kano
BC Canada
Post Number: 1171
At 86dB the speakers do require some power, however at -16dB on the volume scale you should be no where near the power limits of the receiver.
My vote is unless there's a frayed wire somewhere in your connections shorting out, you've got a bad unit. While the 245 might have trouble driving these speakers to their full capability, they should be sufficient at normal volume levels which I suspect they'd be reaching with the 245 at -16dB.
Username: Tc_skier
Post Number: 154
i just realized that it was on logic 7....i switched that up to 2 channel dolby and it seems fine now...the surround mode is probably the only reason that it went into protect im guessing? lemme know thanks.
Username: Kano
BC Canada
Post Number: 1173
Doubt it.
Username: Gamerdude
Ontario Canada
Post Number: 488
So H/k's can run 6 ohms??? I have been wondering for a while even though my speakers are all 8 ohms
Username: Tc_skier
Post Number: 155
damn aight ill call them again then. kyle i wouldnt assume they can run 6 ohms yet but well see. ill update as soon as i know whats goin on.
Username: Nuck
Post Number: 6822
Either of the H/K receivers I have run(AVR55 and 65), have powered my 4ohm speakers without issue.
In fact, the speak's dip to 3.2ohms.
A technic's and a Yamaha receiver wouldn't run them at all.
Username: Tc_skier
Post Number: 156
aight then the 6 ohm is fine obviously.
i got it cranked up to +10 db (max volume) for about 2 whole minutes today (didnt wanna continue killin the speaks any longer) without any problems at all. so it seems like it just went into protect cause it was in 7 channel mode. nuck do you think that makes sense that it would go into protect with 2 speakers on and it in 7 channel mode? im still waitin to hear back from HK.
Username: Gamerdude
Ontario Canada
Post Number: 489
M C I have had mine running surround and only had the fronts pluged in and Mine dnt go into protection(I had other amps running off the preamp section) I think you must has screwed up the wiring. Nuck the AVR 645??? or an older model and how far could you go on the dail before distortion??
Username: Kano
BC Canada
Post Number: 1178
M C do you have the surround back channels turned on? I doubt it will make any difference but if you have nothing connected there set the surround backs to None.
Username: Tc_skier
Post Number: 157
nope wiring's perfect, double checked everything. im startin to think that for 330 bucks i'd rather try and find a good deal on a 345 or 445 when it comes around. i might just get a return authorization number and send it back in. it must be screwd up somewhere...but back channels are off...wirings perfect....idk. is 330 a lot to pay for a 245 refurb direct from harman on ebay? i mean if a higher level harman is available for like 350 then id rather just do that...
Username: Nuck
Post Number: 6856
Kyle the AVR65. Older model. It was featuring AC3 at that time.
Username: Gamerdude
Ontario Canada
Post Number: 490
I piaded like 1000$ new for a local audio store , I really enjoy it though.
Thats prolly why NUck its older(better built??)
Username: Nuck
Post Number: 6900
I dunno. It was under a grand at end of the line at Future Shop. I went back 2 days later and it was 1300. The guy said he got heck for mis-pricing it, sold 3.
Still in service, my son ran 2 subs in a box(2 ohm total) with it as well.
Not my first choice, but it lived.
Thus my(perhaps misinformed) opinion on the brand.
It is a mmm...1997?
Username: Gamerdude
Ontario Canada
Post Number: 491
The thing sounds like a tank!
THe only grips I have about mine(avr-245)
the s/a noice 100db
and the binding post dont seem to be great like the screw on part
other then that its a great reciever
Username: Nuck
Post Number: 6914
I like their products, although I know little about the features anymore.
