New member Username: Trishjones05Post Number: 1 Registered: Apr-07 | ok so i have a record player but i have no idea if it actually works mostly because i have never used it or any other one in my life. but it is a kenwood hooked into a kenwood stereo and when i turn the stereo on the sound is working, but when i put the needle on the record it doesn`t turn at all unless i push it and then it sounds like the chipmunks on helium which is not good. is my record player broken or am i just doing something totally wrong oh and i also can`t find the on button, if there is suppose to be one, i dunno? if someone could help me that would be great! |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10223 Registered: May-04 | . Where's your owner's manual? |
New member Username: Trishjones05Post Number: 2 Registered: Apr-07 | it was given to me and they didn`t include the owners manual |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10225 Registered: May-04 | . Have you tried accessing the owner's manual on line? |
New member Username: Trishjones05Post Number: 3 Registered: Apr-07 | haven`t thought of that, thanks |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10228 Registered: May-04 | . You haven't stated whether this is a direct or belt drive table. I'm guessing belt drive. If that's the case, the belt is probably on the wrong portion of the motor spindle which would cause the speed problem. The belt might also be worn and stretched in which case replacement would be called for. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10229 Registered: May-04 | . Try www.turntablebasics.com |
