Behringer DEQ2496 and DAC compatability - please help
Username: Bvan
Cape Town, Copenhagen,...
Post Number: 273
Hi.
On the Behringer DEQ there are square S/PDIF and XLR AES/EBU connections, but no coaxial digital out like I'm using at the moment between DVD player and DAC.
How can I get the DEQ to feed my DAC?
thanks for any help,
Bevan
Username: Nuck
Post Number: 6825
The dac has no S/PDIF?
Converter cables are available, but the S/PDIF would be preferable.
Username: Bvan
Post Number: 277
Na, no S/PDIF. Only one input. I'm told by its maker that Behringer should have used coaxial rathaer than optical as it has less jitter. Wonder what the consensus is on that one.
Also been told I need to buy a converter. Hope it's lossless. Could have done without another powered item the system - its starting to look like a 747 cockpit.
cheers
b.
Username: Nuck
Post Number: 6828
b, if you need to ad a converter, put it in a chassis that looks nicer with your other stuff.
Maybe an old tape deck chassis or something
Need to Register?
Forgot Password?
Enable HTML code in message
