Good Speaker/Receiver Combination?
Username: Fthomp113
Hello folks,
I'm planning on buying my first stereo system (not counting my old home-theater-in-a-box). I have been doing some research and listening to every system I can get my hands on, and I think I've found about what I'm looking for. However, I'd like some opinions on whether these components are a good match (eg, whether my receiver is too good for my speakers or vice versa).
I plan to use this system for music about 95% of the time, but still want the ability to add surround sound later one. With those characteristics and my budget in mind, I'm leaning toward the following:
Main speakers: Infinity Beta 50 ($500 each)
Receiver: Harman Kardon AVR-245 (or, more likely, the upgraded AVR-247 since that's supposed to be available this month) ($500)
Subwoofer: Depending on how my main speakers sound once I get them set up, I'm looking at getting a Hsu model. ($350 - $500 depending on the model).
Is this a reasonable combination, or am I overspending on one component at the loss of another? Anything else I just have to try out?
Many thanks,
Frank
Username: Nuck
Post Number: 6680
Frank, what is your source?
Generally double the others for the source, if possible, including cables.
Username: Fthomp113
I was actually under the impression that that didn't matter much; as long as it has digital output, doesn't the receiver do the hard work? The source will be a CD player, and I had been looking at a low-end Onkyo or Denon, in the $200-$300 range.
Username: Arande2
Extreme SQ FTW Missouri
Post Number: 2265
I think minimizing jitter is still an issue.
