I have a Sony STR-DE845. The only way i can get it to work is on 2 ch. When i try putting it on normal surround...no sound. I have it on analog. Please Help!..Thank you
IF your Trying to Run them In Surround Through your System it might not work because you Receiver doesnt have Pro logicII, My Reciver doesnt that if i swich it to Surround i cant hear it, so maybe look at ur manual see what your receiver can do. It may also be there a setting you have to change on your dvd player or cd player if that what ur runing to get it to work in surround mode, I hope this helps Some
Pinhead
thank you. now it keeps flashing PROTECTOR! what does that mean?
