Heard the klipsch floorstanding spk rf-83, and man the sounded amazing as i thought they would be... what really stood out was the bass that these spks had... deep, deep bass all the way up.. yeah, i wanted to know if jbl's E-100 would be on par with the klipsch's rf-83, the output of both being 250wts.. and also that the e-100's are far cheaper...
are you still smoking that crack shane? you are comparing klipsch's top tier floor stander to a POS JBL? you retarded or something? Stu, you didn't know? Shane's house is special just like his brain.
doesn't always mean more the cost of the spks better the sound.. so wht if its klipsch top tier floor stander.. i'am sure there are cheaper spks, that would sound better than the83... crack...no.. i guess thats ur department.. christopher the jackass..
Shane, Your the only one who can decide if the jbl's E-100 are equal to the Klipsch. Your ears my not like the klisch so the jbl's may sound better to you.
Although from what i have seen on both speakers if I were considering the RF-83's I wouldn't be comparing them to the E-100's. They don't appear to be in the same league, which is probably the reason for the difference in price.
