The Turn Table Stops
Username: Bennett_s
Cochin, Kerala India
Hi
I have a problem with my turn table. I switch on the turntable and it starts rotating, then i place the record. now when i place the Stylis on the record the turntable goes slow and then stops rotating. What could be the problem? Will it be becasue the motor is weak? Please let me know, Thanks!!!
Username: Jan_b_vigne
Dallas, TX
Post Number: 10124
No name turntables always do that.
What turntable do you own?
Username: Bennett_s
it is a Philips make quite an old one (1973 model) brought from India.
Dallas, TX
Post Number: 10144
You probably need a new belt. For the turntable, that is. Clean the drive surfaces with isopropyl alchohol and a cotton ball, then use a clean piece of cotton with alchohol to clean the belt's surface. But after years of use and/or sitting, the belt is very likely stretched out and should be replaced.
http://www.turntablebasics.com/
Username: Bennett_s
but are belts available for the model which i have as its very old. the problem is that i dont know the model# also. do u need the picture of the turntable.
Username: Nuck
Post Number: 6634
Bennet, belts are available, even if cross-referenced.
What do you mean, no model#.
You are on the net.
Search.
