NAD 3125 or 3150
I'm buying my first amplifier and I'm just wondering if anyone's heard either of these amps. I'm sure the quality is fine, but what about things like power up sounds? What's a good price to pay for them, they're both on ebay but the price is over $50, think that sounds good or do you think a better deal will show up soon?
Thanks
i have a NAD 3150.. and it's a bit old now, you know^^ but i never had problems with it, and it plays great! but i will reccomend you to get an nad 2150 to it, and bridging them.. GREAT power-output... i think it's 170 watt in 8 ohm each channel, but if you use the nad 3150 for itselves in 8 ohm, it's 60 watt.. 4 ohm, 100 watt, 2 ohm, 200 watt. if you need more info, mail me!
