Username: Varney BirminghamEngland, UK
Post Number: 460 Registered: Sep-04
Sunday, March 25, 2007 - 20:16 GMT Is this possible, without a dedicated subwoofer output on the amp? Two, fine quality, screw-down binding posts, with banana facility. Bi-wired to pair of Gale 3030, two way speakers. How does it work; where does it go and can it be done with a 2 channel amp, without blowing it up? Thanks, V
Username: Nuck Post Number: 6476 Registered: Dec-04
Sunday, March 25, 2007 - 20:28 GMT Varney, the sub has speaker level inputs, paralleled to the main speaker leads.
Post Number: 461 Registered: Sep-04
Sunday, March 25, 2007 - 22:10 GMT What...? You mean, you connect the sub to the amp, then run the other two speakers off the sub? V
Username: Nuck Post Number: 6498 Registered: Dec-04
Tuesday, March 27, 2007 - 04:36 GMT Possibly, but not ideally. The sub just 'scabs' a full range signal from the speaker leads (not affecting the impedence load the amp sees)and allows it's own XO to deliver the bass, usually via a frequency selector on the sub. Badda Boom Badda Bing.
