Denon v/s yamaha
Username: Shane24
Post Number: 21
denon's avc-a1xv sounds truly stupendous so is yamaha's rx-z9..
in general which brand makes better a/v receivers and or are they on par?
Username: Frank_abela
Berkshire UK
Post Number: 1964
Shane
Both brands have their advocates and both have their critics.
As you say, the specifications for both of the top-flight receivers read very well. Then again, there's more than one way to skin a cat so they will sound different.
Regards,
Frank.
Username: Claudermilk
CA USA
Post Number: 445
In general, IMHO, they are about on par. You really can't go wrong with either. I have both Denon and Yamaha equipment and am pleased with both.
Username: Alright_boy
Post Number: 62
Try them and make up your own mind unless you need to be led around by a leash.
Username: Gamerdude
Ontario Canada
Post Number: 461
Denon is made in japan
Username: Project6
Post Number: 13531
^^^ and this means what?
Username: Gamerdude
Ontario Canada
Post Number: 464
Its prolly a betty build.
Japan makes better quality stuff over china
Username: Project6
Post Number: 13532
That is a stupid assessment and a really bad sweeping generalization.
Username: Nuck
Post Number: 6485
If the product from China right now is any indication, the product from there will bury all competition within the next 5 years, hands down.
If you buy the right stuff, same as always.
It's even better if you don't have to live there, and ignore trade imbalances and patents.
Username: Stryvn
Post Number: 82
My stuff was made in China. My Japanese friends can't tell the difference.
Username: Nuck
Post Number: 6490
Probably beacuse they all look the same.
The equipment, like.
