Bronze Member Username: Shane24Post Number: 15 Registered: Mar-07 | when it comes to subs... which brand stands out... or known for good subs.. Could anyone suggest a sub of about 250rms, for a sansui amp of 100wts per channel.. i had velodyne in mind.. ur expert opinions guys... (500$ budget) |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1981 Registered: Dec-06 | It depends on if you want it to be loud or have extension. And when you mean amp if you mean an amp or receiver. Velodyne is fine if it's receiver, but if not, and it's an amp, then I like these subs. www.ficaraudio.com |
Silver Member Username: StefanomVienna, VA United States Post Number: 436 Registered: Apr-06 | Hsu Research has a lot of options in your price bracket if you are open to internet direct. All of their models would spank their correspondingly priced Velodyne counterparts in most if not all measurable aspects of performance. They are reputed to sound real good too ![]() |
Bronze Member Username: Shane24Post Number: 19 Registered: Mar-07 | yeah, i mean integrated amplifier.. thanks anyways.. |
Platinum Member Username: Project6Post Number: 13516 Registered: Dec-03 | I second the HSU subs. Well within budget. |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1983 Registered: Dec-06 | Yes^^ |
