Hi, I have a Onkyo 797 Amp, When I plug my RCA cable into the Sub output, I do not get any output to my sub, If i plug it into any other output say - Front Right, The sub works.
Anyone know what I may be doing wrong?
Or is my AMP dead?
Thanks MaxW
Ohh And Subwoofer is set to yes in the speaker config!
Tom
Make sure you config the speaker correctly. The SUB is turn off by default. You must turn it on. Choose setup menu and browse through the menu. You will find it.
Tom
Don't plug your SUB input to any none SUB PRE-AMP output. If you SUB does not have a built in high frequency filter. Those high frequency would kill or degrade you SUB performance.
