Silver Member Username: Tc_skierPost Number: 132 Registered: Oct-06 | Could someone explain to me the difference between a receiver and an amp? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10041 Registered: May-04 | . http://eli47.tripod.com/audiogloss.html#q-r |
Silver Member Username: Tc_skierPost Number: 134 Registered: Oct-06 | so a receiver basically combines a pre-amplifier, a power amplifier, and a radio right? What would be the advantage of getting a preamp and amp instead of the receiver? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10044 Registered: May-04 | . Hopefully better design and construction, typically less features so the money is spent where it counts - on the sound quality, pieces meant to do just one job rather than a dozen, components that have a power supply designed to suit their specific needs and not the needs of a group of components (low voltage and high voltage separated not combined) and the layout in an individual chassis instead of cramming everything together in one box. You also get the opportunity to mix and match brands or models to achieve the system sound you want without buying unnecessary stuff and you can upgrade at any time by swapping to a new pre amp or power amp giving you far more flexibility in your system design. Separates also look way better. There are downsides to separates other than cost but they are fairly minimal. . |
Silver Member Username: Tc_skierPost Number: 135 Registered: Oct-06 | ah thank you for clarifying that. |
Bronze Member Username: ChicomoralessxmDutch islesCaribbean Post Number: 91 Registered: Feb-07 | jan Like what negatives??? do enlighten me the main reason i think of is price??? possiblely space but i have never thought of others |
