Overall best type II tape from Maxell or TDK
Username: Interlude
NJ USA
For the best performance, overall, which type II tape from these two manufacturer's would you use -- Maxell XLII-S or TDK SA-X?
Username: Alright_boy
Post Number: 80
Maxell XLII-S. However, depending on your recorder, of course, TDK will tend to give you a brighter top end.
Need to Register?
Forgot Password?
Enable HTML code in message
