New member Username: JimtmcdanielsColorado springs, Colorado Usa Post Number: 1 Registered: Mar-07 | Can anyone help with this situation: I have a nutone home intercom system and one of the speakers voice coil has gone out. I can't find a replacement speaker, and they want too much $$ for the whole unit that contains the speaker. I can't find a new speaker, it's a little 3 1/2", 16 ohm speaker. Noone carries 16 ohm.. Is there somewhere I can order one of these? Can I order a 4 ohm and add a resister in line to one of the connections to make it 16 ohm resistance?? More of these units are probably gonna go out over the years, hopefully I can find an affordable replacement speaker. Thanks for any help! |
Gold Member Username: NuckPost Number: 6330 Registered: Dec-04 | Yes, James, you can add a resistor. But this might create such a load thet the power supply cannot output against it. Are new intercoms expensive? Never looked... |
Platinum Member Username: Project6Post Number: 13427 Registered: Dec-03 | You can also try parts express. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9999 Registered: May-04 | . If they're all going to go out, you might as well get a new system. Sometimes it's best to suck it up and buy the original equipment rather than jerry-rigging something. Do you know whether the intercom has a 25 volt transformer output? If so, you'll probably end up buying from Nutone. Have you tried an internet search for 16 Ohm intercom speakers? Buy two eight Ohm speakers and connect them in series. . |
New member Username: RpinellRichardson, TX US Post Number: 1 Registered: May-07 | James, hopefully I'm not to late. But you may want to talk with two companies that specialize in intercom repair. They have years of experience on repairing Nutone and M&S for many years. They may have the parts your looking for and they are www.allelectronicsrepair.com or www.skelectronics.com. If you have further questions I'll be glad to help. I can be reached at 877-435-0670 or go to www.intrasonictechnology.com . |
