NAD 325BEE as NAD C272 preamp
Username: Herold
Hi,
Anyone with experience using NAD C325BEE as a preamp for NAD C272 power-amp ?
Any differences (quality, performance) between NAD C160 preamp and C325BEE used as a preamp ?
Regards
Herold
Username: Markdavid
Post Number: 7
C 160 is better .
Username: Markdavid
Post Number: 8
NAD C 160 is better
Username: Jingka99
Post Number: 206
Hi Herold, currently I'm using NAD C352 as preamp to C272, though I had good results, I am also wondering whether the preamp in C352 is comparable to C162 which is the preamp match of the C272.
https://www.ecoustics.com/electronics/forum/home-audio/353628.html
I might be able to check this out with my dealer, I'll let you know soon...
I am also pondering on the idea of using tube-preamp such as ARC LS3 and the like...
regards-arnold
Username: Sun_king
Leeds, West Yorkshire UK
Post Number: 370
Most NAD pre-amps sound the same, by that I mean upgrading to the C162 won't offer you much of an improvement. The S100 would be an improvement.
Username: Jingka99
Post Number: 212
Hi SunKing, how about tubed-preamp with C272? Thanks
Username: Unbridled_id
ChicagoUsa
Post Number: 190
Ever consider a passive pre amp ? I use one with the C272 and like it. http://www.ftaudio.com/
Username: Sun_king
Post Number: 371
Tube pre-amps are great but like anything in hifi it all depends on the system it is going into. If you have the right speakers and amp, a tube pre is great. Get the formula wrong and you can have a warm, syruppy system. So always try to listen in your own system before you buy!
Username: Jingka99
Post Number: 215
I am considering EAR 834L, I listened to it yesterday with NAD C270+ATC SCM 11 and it was really good to my ears, the tubes are the original ones, i've read that using better tubes brings out the best on this preamp...
Another option would be the audible illusion modulus 3 preamp though i have not heard this...
And last is ARC SP9 MKII, there is a pre-owned one, but the same, have not heard this one...
Which of the three would be my best bet with NAD C272? Any ideas please...
