New member Username: TreggeeePost Number: 2 Registered: Oct-05 | Hi, If anyone could help me it would be great. I have a Dell Inspirion E1705. It has: Audio jacks: Stereo headphones/speakers miniconnector (same as line-out), microphone miniconnector. ExpressCard slot. not a PCMCIA. What are decent speakers under $200 for this type of setup. I have a lot of parties and need good sound. Thanks, ![]() Much appreciated |
Platinum Member Username: Project6Post Number: 13367 Registered: Dec-03 | You want to use the computer for parties and you want good sound??? Pretty tall order. You will be hard pressed to find computer speakers that can hold parties. |
New member Username: TreggeeePost Number: 3 Registered: Oct-05 | house parties ![]() |
Platinum Member Username: Project6Post Number: 13369 Registered: Dec-03 | Shop around for logitech speakers in that price range. You'll find plenty that is powered and could probably hold a small house party up to acceptable levels. ![]() |
New member Username: TreggeeePost Number: 4 Registered: Oct-05 | Is it a 2.1 i need to plug into the microphone jack? |
Platinum Member Username: Project6Post Number: 13371 Registered: Dec-03 | No the speaker jack. |
Silver Member Username: SerniterPiscataway, New Jersey USA Post Number: 132 Registered: Mar-06 | For parties, I'd second Logitech http://www.newegg.com/Product/Product.asp?Item=N82E16836121122&ATT=36-121-122&CM P=OTC-B1zrat3 |
New member Username: TreggeeePost Number: 5 Registered: Oct-05 | I dont have a speaker jack. Check out my configurations. Its just the microphone and headphone jacks. And the express card, which is in its infancy so docking stations are to expensive right now. |
Silver Member Username: SerniterPiscataway, New Jersey USA Post Number: 133 Registered: Mar-06 | Most computer speakers can be plugged into the headphone jack. The Logitechs too. |
Silver Member Username: SerniterPiscataway, New Jersey USA Post Number: 134 Registered: Mar-06 | If volume was not a high priority, I would check out the Klipsch Promedia too. They are not loud like the Logitechs, but are better for music. http://www.amazon.com/Klipsch-ProMedia-2-1-multimedia-speaker/dp/B000HI5ETM |
