Bose Cube Speakers
Username: Jim_brown
I need some guidance. I currently use JBL speakers on my rear channel. I am thinking of replacing them with Bose cube speakers. What I need to know is will the speakers work fine without the bass module or do they have to be connected as to mfg. specs. My main speakers are 301's and a 150w sub.
Thanks, Jim
Username: Thx_3417
Bournemouth ...
Post Number: 3040
Username: Thx_3417
Bournemouth ...
Post Number: 3041
Stick with JBL it's the best it's the first to have been used in the cinemas it the best all round sound.
Username: Stefanom
Vienna, VA United States
Post Number: 426
To answer your question, you don't want to hook the cubes up directly to your receiver. The bass module has a crossover built into it which adjusts the output for the attached cubes.
