New member Username: DangergirlPost Number: 1 Registered: Mar-07 | Hi, I tried setting up the surround sound on my kenwood receiver but having problems. When testing the speakers they all seem to work but only the front r/l speakers work when the receiver is being used. The receiver only shows the r/l speakers on the screen and no matter what buttons I push, I can't get the center, sub or rear speakers to work. Can anyone offer any suggestions how to fix this? Thanks! |
Gold Member Username: NuckPost Number: 6121 Registered: Dec-04 | Kim, what input source are you using, and into which connections? Your player may not be configured properly for 5.1. Have you check the connections section of the manuals? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9906 Registered: May-04 | . I assume this is a new receiver. If so, dealer support is your best choice. Can I assume you paid for that feature/benefit/advantage? |
Gold Member Username: NuckPost Number: 6130 Registered: Dec-04 | Again, here it comes. Like I said before. How is your dealer helping you? |
New member Username: DangergirlPost Number: 2 Registered: Mar-07 | This is a used system. I got it several years ago. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9929 Registered: May-04 | . Do you have the owner's manual? |
Silver Member Username: Bill984Post Number: 245 Registered: Oct-05 | get the manual here http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69 |
New member Username: CandydPost Number: 1 Registered: Apr-07 | How do you turn the mute off on the VR406? It doesn't have a mute button and I have no idea how it got turned on. |
