Speaker glue
Username: Dustcanblue
Hi Guys
I have a set of Paisley SPL monitor the foam on the outter edge of the speaker detach itself from the cone wich is somekind of plastic. The foam is not damage at all. I was wondering if somebody had the knowledge of what kind of glue they used or tips on how to fix that. Any help would be greatly appreciate. Thank you.
Robert
Username: Jan_b_vigne
Dallas, TX
Post Number: 9904
Try contact cement. Be careful, once the two pieces touch, they are forever bonded in that spot.
Username: Nuck
Post Number: 6116
Robert, I had those. Do you have 10's or 12's?
Nobody else has heard of them, and API does not stock parts.
Ian Paisley did a wonderful job on these as an upper line to the Acoustic Research line that API was using his name for.
Those Paisley's were all his design.
Username: Nuck
Post Number: 6117
Try nail polish on similar materials before hand, It is not so flexible, but will not crack.
Dallas, TX
Post Number: 9907
"Try nail polish on similar materials before hand ... "
Good one, Nuck.
Username: Nuck
Post Number: 6135
The bass player punched one of the Marsland bass bins on the way out, I mended it with the nail polish(yes, pink), but that was a cardboard Marsland 200w 15" driver, with 120 oz magnet.I spotted the suspension(neo or something close) with the polish as well.
I believe in the nail polish, at least for low drivers.
BTW, he hit it as hard as he could, one little crack in the surface.
Them be tough.
BTW, I also banged the chick that donated the nail polish.
Dallas, TX
Post Number: 9915
And her name was, Mrs. ... ?
Username: Nuck
Post Number: 6136
Tuesday.
Ruby.
Hey, I was a kid.
Username: Nuck
Post Number: 6137
pssst, she didn't ask my name.
I'm the drummer, remember?
Username: My_rantz
Australia
Post Number: 1229
And it was goodbye Ruby Tuesday!
Username: Nuck
Post Number: 6144
Who could hang a name on her?
Still I miss her.
Slow day on the forum.
Username: Nuck
Post Number: 6145
Robert, I really want to know about your speaks, my brother has them now.
Dallas, TX
Post Number: 9919
What a rock and roll god.
Username: Nuck
Post Number: 6148
Back to Robert's speaker Q.
Hi guys
They are SPL-4000 they have 2 x 10" speaker and a tweater, the size is 12.75" x 15" x 42.75"h.
Robert
Username: Nuck
Post Number: 6184
Robert, I had the 12"'s(5000's)? but the drivers are both peerless.
You might pull a woofer and scan the unit for #'s, they may be available from someone else. BUT, if one is breaking down, the others will follow closely behind(barring physical damage.)
Replacing one unit is taboo, and major repairs to one driver will disrupt the balance, if not perfectly accomplished.
Ideally, you could replace the quartet, if the right drivers are available.
Have you had the speakers apart?
No I didn't take it apart yet I was just trying to figure out the best thing to do.
Robert
Username: Nuck
Post Number: 6185
Robert, I pm'd you back.
You are going to have to open them up and get some info.
If you got them cheaply enough, the replacement pars may work out well for another 20 years.
I think yours are like 1983 or 4
