Martin Logan Dynamo vs. Hsu VTF-2?
Username: Bebopdeluxe
Post Number: 17
Any thoughts?
The VTF-2 seems like a giant-killer - particuarly at the $250 price point that a used one can be found on at Audiogon...but the Dynamo seems to get its share of respect as well.
Music only - no HT.
Thanks!
Username: Stefanom
Vienna, VA United States
Post Number: 412
Note that there are several different iterations of the VTF2, so that will affect the outcome. At 250 bucks though, I'd say any of them would be a great value.
On the other hand, the Dynamo is a great music subwoofer; however, its output will be somewhat limited compared to the VTF, so if your room is large, or you like to blast it, the Dynamo might not be the best choice.
