Bronze Member Username: BigbadwormSan Diego Post Number: 41 Registered: May-05 | I was given a pair of these ( pioneer cs-r590 ) the other day and would like to put in my garage for when I'm working on the car, or just hanging out. Any ideas on a used receiver to power these? I'm looking cheap on Craigslist but not sure what to look for. All I'm going to be doing is hooking up my Sirius to it and listening to Music and sports talk. Any input would be much appreciated. |
Bronze Member Username: ShawnharmanPost Number: 67 Registered: Dec-05 | http://www.vanns.com/shop/servlet/item/features/538499490?v_c=PriceGrabber, try this out, I dont know how much you are wanting to spend. |
Bronze Member Username: BigbadwormSan Diego Post Number: 43 Registered: May-05 | Yeah a little too much for me. How is the H/K 3480? They are around $200 on Ebay. |
Bronze Member Username: ShawnharmanPost Number: 68 Registered: Dec-05 | the H/k will actually blow that yammy away. I have one and it is awsome, but since your useing it in your garage, I would look into the H/K 3380, its cheaper and it will make those pioneers rock! |
Bronze Member Username: BigbadwormSan Diego Post Number: 44 Registered: May-05 | I went ahead and ordered the 3480 from Harman refurbished for less than $200. Only $20 more than the 3380 so I said why not. |
Bronze Member Username: ShawnharmanPost Number: 69 Registered: Dec-05 | well then you just got a really good deal, you will love it. |
