Bronze Member Username: AudiobuffPost Number: 33 Registered: Jan-07 | I need a good pair of party speakers. They need to be able to kick out alot of bass and a nice high SPL. I was looking at the Cerwin-Vega VE-15F's. Does Cerwin make decent equipment or are there other brands you would recommend? |
Gold Member Username: KanoBC Canada Post Number: 1149 Registered: Oct-04 | Vintage CVs can be quite good, buying new I'd look at Klipsch for a speaker that plays as loud but with better detail, imaging, and accuracy. http://www.vanns.com/shop/servlet/item/features/540999853 |
Silver Member Username: GavdawgUpstate, New York Post Number: 363 Registered: Nov-06 | I will throw in the Wharfedale Zaldek line as well... http://froogle.google.com/froogle?q=wharfedale+zaldek&hl=en&client=firefox-a&rls =org.mozilla:en-US:official&hs=50B&sa=X&oi=froogle&ct=title |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1725 Registered: Dec-06 | I'd probably grab a bunch of really cheap speakers and a movie theater subwoofer, then some amps. After looking at the price I'm sure 2 sets of those CW's + a JBL Pro Sub and WHAM! Here are some JBL Subs (Note the sensitivity): http://www.jblpro.com/pages/cinema/lfsub.htm Here are some other speaks (sensitivity): http://www.jblpro.com/pages/cinema/3000.htm Amp: http://www.behringer.com/EP2500/index.cfm?lang=ENG That's just me though. I can see you don't want to spend a fortune, so I tried to max out the price/performance ratio. |
Silver Member Username: GavdawgUpstate, New York Post Number: 366 Registered: Nov-06 | Andre, that sub would cost about a grand, if not more. I know Klipsch pro theater subs are expensive. Here is a link to a JBL DJ subwoofer, which is priced at $900 with a discount. The cinema subwoofer would be even more expensive IMHO, because the level of refinement "should" be higher. http://www.americanmusical.com/item--i-JBL-MRX528S.html Sending a link to the cinema speakers makes me keenly aware (once more) that you have no real clue as to the price For that kind of money, you'd be better off with the Klipsch LaScala, or possibly even higher up the Klipsch line. |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1727 Registered: Dec-06 | Actually, they're about the same. I never looked at the prices on cinema speakers though. Just a sec.. Cheaper Sub: http://www.nextag.com/JBL-3635-18-300Watt-505259685/prices-html Speaks: http://www.bhphotovideo.com/bnh/controller/home?A=details&kw=JB3677&is=REG&Q=&O= productlist&sku=433098 I'm not sure if that's each, but I think it is. Maybe you're right, but I'd probably pay those prices if I were wanting more SPL, from both woofer and horns. The most powerful JBL Cinema Sub goes for $1000 at some places. I trust B&H, my dad's done multiple purchases there. |
Silver Member Username: GavdawgUpstate, New York Post Number: 367 Registered: Nov-06 | those are the cheapest in the lineup... FWIW, the sub for $580, that really surprises me. I still wouldn't recommend it though. Paired with the cinema speakers, it comes to almost $1800. You could get a nice pair of brand new Klipsch Heresey's for that price. A pair of CV or Klipsch Reference floorstanders (or the Hereseys for that price) would most likely be a better choice, unless the OP is looking to fill a ballroom. Yes, the last part of my post above was facetious. |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1731 Registered: Dec-06 | I thought he said it was for lots of bass and a party? In that case I'd just get a pair of the CW's, that amp for those. One of the subs + that amp = WHOMP WHOMP. |
Silver Member Username: GavdawgUpstate, New York Post Number: 370 Registered: Nov-06 | party speakers= probably for a party. :-P |
Gold Member Username: NuckPost Number: 6082 Registered: Dec-04 | Reminiscing over my college speakers brings a tear to my eye. And a ringing to my ears. |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1738 Registered: Dec-06 | Give me a "Nuckle" Sandwich. |
Bronze Member Username: Rock_hardPost Number: 43 Registered: Sep-06 | build some yourself for way cheaper. i made a cheap set of speakers...didn't put much effort into the box design but built it very solid...phoned up Solen and they designed my crossover for my Peerless components. i have people over every weekend and we listen to EVERYTHING. Loud screaming heavy metal to reggeaton to girly pop music to hardcore rap. Let me tell you, these things take everything. they are incredible. i'm powering them a behringer a500 amp and they will take whatever i throw at them. I was so impressed i'm building this set of speakers (http://customanalogue.com/elsinore/elsinore_index.htm) note: These are called the Elsinore speaker...they have no made the Elsinore MKII using the Peerless HDS tweeter rather than the Vifa. These are going to be amazing. |
Gold Member Username: NuckPost Number: 6114 Registered: Dec-04 | The speakers look interesting, the place looks like my outhouse.LOL! Tim has ready to go designs at Alegriaaudio.com Not so sure about the transmission line or multiplexed mid woofers |
Bronze Member Username: AudiobuffPost Number: 44 Registered: Jan-07 | Thanks for the input guys! |
Gold Member Username: NuckPost Number: 6167 Registered: Dec-04 | You are welcome, as always, Buff. |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1797 Registered: Dec-06 | Catch your house on fire with this as a party speaker! http://www.antiqueweekend.com/x/main.htm |
Gold Member Username: NuckPost Number: 6174 Registered: Dec-04 | Andre, wayyy off topic. And really neat. |
