New member Username: RadugaPost Number: 1 Registered: Feb-07 | Hi, I'm a total newbie when it comes to hi-fi audio. I'm also on a budget, and I seem to have found the perfect amp for music listening in my tiny bedroom: the T-Amp. I saw some very long discussion threads about this amp, but I haven't seen much about the newer Super-T. Maybe I just missed it. Anyway, how does this compare to the original T in sound quality? Pretty much "the same or better", right? Also... I need some speakers for this amp. I was pretty psyched about the Paradigm Atom Monitor v.5, but these recommend 15W of power. So they wouldn't work well with the T-Amp? Any other *small* (8Wx11D max) speaker recommendations for under $300 that would match well with the T-Amp? Again, this is for music at close range. thanks (: |
Silver Member Username: GamerdudeOntario Canada Post Number: 417 Registered: Apr-06 | hahaha Dont worry about the power rating Look for HIGH sensitivity speakers KLipsch,Paradigm Allso if it were me i'd get the super T cause of wal adapter and all that other junk plus binding post i couldnt really find anything on those speakers but my guess is that it shoudl work fine |
New member Username: RadugaPost Number: 2 Registered: Feb-07 | After further investigation, I see that the Atoms are rated at "in-room sensitivity of 90dB (87dB anechoic), and recommends amplifiers with outputs of 15-80Wpc". So is that considered the correct sensitivity for this amp? |
Silver Member Username: GamerdudeOntario Canada Post Number: 418 Registered: Apr-06 | Ahh shouldnt be bad I dont know too much about this amp , you should ask Jan she has one |
Gold Member Username: NuckPost Number: 5994 Registered: Dec-04 | raduga, punch "T-amp" into a search engine and have a good deal of time to spare. More sensitivity=more volume. How good is up to you. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9839 Registered: May-04 | . https://www.ecoustics.com/electronics/forum/home-audio/193312.html |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9840 Registered: May-04 | . https://www.ecoustics.com/electronics/products/reviews/209464.html |
Bronze Member Username: AnubisBirmingham, West Midlands England Post Number: 71 Registered: May-06 | The T-Amp has fascinated me ever since I first saw it mentioned in here. I've always suspected this amp would be built into a sturdier, more attractive package and sent out at the price of real hi-fi. It's cheap, so I guess many people will overlook it. I've yet to actually hear one. I once rang around hi-fi dealers in my own town and they had never heard of it. V |
New member Username: RadugaPost Number: 3 Registered: Feb-07 | Thanks for the suggestions, all. After more online research, I went ahead and purchased my first amp and some new speakers last night. I selected the Trends Audio TA-10.1 amp, based on the same family of IC chips as the original T-Amp. The various reviews for this amp are glowing, and I really liked the small size and aluminum case. The $99 price helped a lot too For speakers, I found a pair of Athena Technologies Audition AS-B1 on special for $150, so I jumped on it. They've got an advertised sensitivity of 91dB, so it seems like a good match for the T-amp and my small listening space. At about 9x7x14" they're a bit bigger than I wanted, but I guess I'll grow into them, and maybe eventually use them as fronts in a theater setup. Can't wait to hear 'em... |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9857 Registered: May-04 | . I'm sorry, did I miss where the reviewer actually reviewed the amplifier? Good luck, raduga, get a good source and you should have great success with your system. http://www.gcaudio.com/resources/howtos/index.html Pay attention to speaker set up. http://www.tnt-audio.com/casse/waspe.html . |
New member Username: Thomasj3577Post Number: 2 Registered: Apr-07 | There is a review of the Super T amp at Stereomojo.com. They also did a shootout of 14 other T and D class amps. |
