Intermient hum in the receiver
Username: Ssin680
Post Number: 16
Hi,
I just installed my new system including a Harman Kardon AVR 445 receiver and when the receiver is in use for a certain time (15 to 30 minutes) I begin to get an intermitent noise coming from the receiver itself.
It lasts about 2 minutes, then stops, then begin again a few minutes later, etc..
Any help will be appreciated !
Charles
Username: Jan_b_vigne
Dallas, TX
Post Number: 9844
"Sounds" like a cooling fan switch in and out.
Username: Ssin680
Post Number: 17
Hi,
Is this "normal" with this receiver or is there a way to attenuate it ?
Charles
Dallas, TX
Post Number: 9865
You'd have to ask either the dealer or HK whether it is "normal". If all is as should be, there isn't any reason to lower the volume of the fan as that would lower the benefit of the fan.
