Bronze Member Username: PrideboyOmaha, NE USA Post Number: 11 Registered: Feb-07 | I found a speaker that is about the same price as the Control ONE at Best Buy and the Sony SS-MB350H looks like a great speaker and it says that it goes to 50khz high and it uses Kevlar woofers and mid range but I guess I was wondering is that is the Control ONE better than the big Sony bookshelf one? I will be mainly using them for music listening and for playing games on my PC since my receiver is connected to my desktop PC. Here's a link to the Sonys I'am thinking to buy. http://www.sonystyle.com/is-bin/_3Cwbr+target=_blank_3EINTERSHOP.enfinity/eCS/St ore/en/-/USD/SY_DisplayProductInformation-Start?ProductSKU=SSMB350H&Dept=tvvideo &CategoryName=hav_HiFiComponents_Speakers |
Platinum Member Username: Project6Post Number: 13054 Registered: Dec-03 | Yup, that Sony looks like it is great...but no they are not. |
Silver Member Username: StefanomVienna, VA United States Post Number: 384 Registered: Apr-06 | If you're looking for a relatively cheap but good speaker, try out the Insignia bookshelf from Best Buy Dallas. |
Silver Member Username: SerniterPiscataway, New Jersey USA Post Number: 122 Registered: Mar-06 | I second the Insignias. This Sony speaker is not good. |
Bronze Member Username: PrideboyOmaha, NE USA Post Number: 30 Registered: Feb-07 | Is the Sony SS-MB150H a better speaker than the Control 1Xtreme since it goes to 50khz and has more power handling. I also see that they both are same size cones and tweeters. Here's a link to the Sonys I am talking about. http://www.bestbuy.com/site/olspage.jsp?skuId=5378799&type=product&productCatego ryId=cat03043&id=1051806316624 http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_Display ProductInformation-Start?ProductSKU=SSMB150H&Dept=tvvideo&CategoryName=hav_HiFiC omponents_Speakers |
Platinum Member Username: Project6Post Number: 13072 Registered: Dec-03 | No it is not. Specs mean squat on a Sony. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 4130 Registered: Feb-05 | The Sony is not a good speaker.....period. Try the Insignia or cheap Infinity's or Polk's or Mission's. Look up these brands online dealers someone will certainly have a deal on at least one model. If you're gonna throw your money away on the Sony's you might as well go find a white van and buy some speakers..at least they're big. |
Bronze Member Username: NadzCalifornia Post Number: 36 Registered: Aug-05 | Haven't you learned already that these speakers are both poor. How many people have to tell you this. Why do you keep asking the same questions. Look at companies such as Athena, PSB, Paradigm, and Energy. They all have budget speakers that are far superior to the crap your looking at. |
Bronze Member Username: PrideboyOmaha, NE USA Post Number: 31 Registered: Feb-07 | Have you guys heard the Sonys before?? It seems like you are very sure that the Sonys aren't good like you guys have listen to them. Have you guys compaired them to the Control 1Xtremes? |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 4134 Registered: Feb-05 | Buy what sounds good to you Dallas, after all it's your money. |
Platinum Member Username: Project6Post Number: 13075 Registered: Dec-03 | Dallas, you asked, and we gave you an answer. But it seems like you are bent on getting the Sony's, go for it man, more power to you. I've listened to plenty of Sony speakers and they just don't sound good no matter what the specifications are. The thing is, most of us have listened to a lot more other speakers and Sony's just don't cut it. You really seem impressed by the specs of the Sony, and as Art stated...it is your money. Spend it the way you see fit. Just don't ask for opinions if you are not willing to hear them out. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 4135 Registered: Feb-05 | That's it Berny. |
Silver Member Username: GavdawgPost Number: 311 Registered: Nov-06 | This guy is a troll... a quick look of the history of SpankingVanillaIce over at the AudioReview forums reveals not only is he... a) pestering them with questions on the JBL Control speakers, worded the same as the questions as he posted in here, but seemingly found the answers. b) stated that he already bought a pair of Sony speakers. this is the last time I answer one of his posts. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 4136 Registered: Feb-05 | Thanks Gavin. |
