Bronze Member Username: Malco49Baltimore, Maryland Usa Post Number: 59 Registered: May-05 | what are the best alternatives,keeping it real under say $100(USD) hopefully well under |
Silver Member Username: Two_centsPost Number: 810 Registered: Feb-04 | How does an effective stylus cleaner for under $3 sound? http://db.audioasylum.com/cgi/m.mpl?forum=vinyl&n=391752&highlight=magic+eraser+ Mr.Radar&session= The Mr. Clean Magic Eraser should be used dry. Cutting off a small block and attaching it to a wood skewer or coin makes it easy to use. |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1937 Registered: Sep-04 | Lyra SPT |
New member Username: RevolverPost Number: 5 Registered: Jan-06 | I agree,I just got The Lyra SPT today and so far I find it better than the Discwasher,the Clearaudio Elixir and the Vinylcare cleaner.All of which are ok up to a point. The worst I found was this : http://www.tnt-audio.com/clinica/glassrubber_e.html I got a similar item to this off a friend ,who uses them in the electonics industry. At first it I thought it was great till I "cleaned" the tip right off my g1042 ,Ouch! 90 quid gone in a few seconds. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9810 Registered: May-04 | . Don't know about your g1042 but bonded styli need special care with any cleaner. Most high end cleaners are meant for use only with n-u-d-e mounted styli. |
New member Username: RevolverSkelmorlieScotland Post Number: 6 Registered: Jan-06 | That's what I like about the Lyra ,it gets the stylus clean with just a very gentle brushing action. The Goldring G1042 has a n-ude stylus. |
Bronze Member Username: AudiomaniaMuskegon, MI USA Post Number: 26 Registered: Dec-04 | Any opinions regarding a product called "Needle Nectar" for cleaning the stylus? |
