New member Username: JdhoggPost Number: 1 Registered: Feb-07 | Not really sure what "Plasma friendly" means, but I am looking for some wall-mounted speakers to complement my Panasonic 58" and Denon 2307CI in a 3.1 system. Any thoughts on these: Polk: L/R--RM7300/RM30, C--RM7302/RM302 DefTech: L/R--Mythos Two(or Six), C--Mythos Three(or Seven) RBH: L/C/R--WM-30 Klipsch: L/C/R--Synergy SLX LCR This is for a rather large den and towers are not an option (unfortunately). I may go to a 5.1 system with some in-ceiling/corner speakers once I commit to putting some holes in my walls. |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1934 Registered: Sep-04 | John, I don't know the speakers you mention so I can't comment on them. One very nice solution which I rather like for its clean look (plasma friendly) is the Artison Portrait. These are speakers designed to look like they were made for the plasma screen. They come with a rig that attaches to the rear of the screen. In each speaker chassis there are actually two speakers. The top speakers act together (very well) as a centre speaker. The two bottom speakers are left and right channels. The rear of each chassis has a side firing tweeter to add ambience. So these two speakers give you 3 channels. Just add a Velodyne sub for the .1. Alternatively, another very effective solution is the Totem Tribe. This speaker is long and slim and you can buy them singly, to place on the wall. They're better speakers than the Portraits but obviously you have the palaver of attaching them to the wall. They work far better than they have any right to. Regards, Frank. |
Bronze Member Username: Malco49Baltimore, Maryland Usa Post Number: 58 Registered: May-05 | frank although this is not directly related wanted your opinion on a couple of issues. 1.just bought two set of bright star isonodes for cd and amp.(speakers are isolated on the posts and rubber bits supplied with the PSB's).what do you think of these isonodes? 2.what stylus cleaner would you recommend.i don't play loads of vinyl maybe 6-7 lps's per month have pro-ject debut 3 with supplied stylus ortofon. thanks malco |
Gold Member Username: HawkHighlands Ranch, CO USA Post Number: 1186 Registered: Dec-03 | John: The weakness of most of these wall mounted speakers is that they lack low end extension--most roll off at 90Hz or at best 80Hz. It is no problem when listening to Home Theater with a dedicated subwoofer, but if you listen to stereo music, it will sound like something is missing (because it is). Don't know what your budget is, but look into the Dynaudio 42Ws. These are small boxes that mount directly to the wall and they are about 14"h x 9"w x 7"d. They go deeper, and are far more natural sounding that the speakers you identified. Alternatively, check out the NHT L-5s, which are also speakers meant to be wall mounted with a plasma or LCD tv. They also have a much more convincing full range capability. |
Silver Member Username: GavdawgPost Number: 284 Registered: Nov-06 | I would also recommend taking a look at the MartinLogan line of on wall speakers. These are specified to have a low end extension of approximatly 75Hz at the -3dB point. They are stunning with music (with a subwoofer), and are equally adept at home theatre. http://www.us.martinlogan.com/speaker_intro/fresco.html http://www.us.martinlogan.com/speaker_intro/vignette.html The frescos are priced at $1000 each, and the vignettes are priced at $650 each. These speakers use planar magnetic technology to reproduce the highs (and the midrange as well in the case of the fresco). They are lightning quick, and reproduce transients with stunning realism. The midrange (especially in the fresco) has an almost "reach out and touch it", you are there feeling, without being too forward. MartinLogan on wall speakers are unlike any other sealed on wall speakers (that I know of). They are planar loaded, and are adept at music and home theater. Although you will need a subwoofer, it is not hard to find an inexpensive (less than $600) subwoofer that will work well with these. There are options all over for great subwoofers, and some are even less than the $600 I put for an inexpensive subwoofer. That is a ballpark figure. These speakers aren't inexpensive for an on-wall. Many outstanding floorstanders are in the $1200 to $2000 a pair category. They offer deeper bass (and may sound similar in the case of ML's own Montage) But, these truly are great speakers and IMHO well worth the price if your budget allows. However, for general TV viewing, a subwoofer will not be mandatory. I would just recommend it if you are also looking for an outstanding music system as well. |
Silver Member Username: DavidpaPortland, Oregon US Post Number: 389 Registered: Nov-05 | Why can we never just give input on what speakers the OP has considered, and go from there? Instead of injecting personal preferences? I recommend Aerial Acoustics. No sub required either. So there. |
Silver Member Username: DavidpaPortland, Oregon US Post Number: 390 Registered: Nov-05 | Oh, and their not wall mountable, so change the setup too! |
Silver Member Username: GavdawgPost Number: 285 Registered: Nov-06 | because I feel that more speakers than just 3 are needed to narrow down your choices. If he had posted 5 or more, than I may not have done what I did. |
