New member Username: Jimbocableguy57Jonesboro, AR US Post Number: 1 Registered: Feb-07 | Just got a Mint Pioneer VSX-9700s. Hooked it up and no rear or center channels. Does not work with test tone either. I have checked it all! ANY suggestions ?????? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9783 Registered: May-04 | . How can it be "mint" if it doesn't work? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9784 Registered: May-04 | . Sorry, I forgot. It's a Pioneer. Yep, it's "mint" alright. |
Gold Member Username: NuckPost Number: 5878 Registered: Dec-04 | It's a pioneer buyer, do not blame the gear. |
Gold Member Username: NuckPost Number: 5879 Registered: Dec-04 | Ignore last post. Hammered. |
New member Username: Jimbocableguy57Jonesboro, AR US Post Number: 2 Registered: Feb-07 | Thanks for the help and encouragement. This forum was worth all I paid to join! |
New member Username: Jimbocableguy57Jonesboro, AR US Post Number: 3 Registered: Feb-07 | And by the way, Mint was the discription I was given before payment, sucker was my title after. I think I can get a refund. Any suggestions for new, and I guess not Pioneer |
Platinum Member Username: Project6Post Number: 12993 Registered: Dec-03 | Set a budget first. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 4061 Registered: Feb-05 | Hi Jim. What's your budget, application, listening preferences etc? What's your source, speakers and so on and so forth? What are you listening to now? |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 4062 Registered: Feb-05 | BTW I think Nuck's home after a few days on the road....he's really OK....right Nuck....right! |
New member Username: Jimbocableguy57Jonesboro, AR US Post Number: 4 Registered: Feb-07 | 700$ range and mostly home theater, and don't wory, I can take it, some of it is deserved. |
Gold Member Username: NuckPost Number: 5883 Registered: Dec-04 | Indeed. Pioneer is current with most of the brands nowadays. The Elite brand demands sommore money, and warranties their product for a more reasonable amount of time. The stuff just should not break. It never used to. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 4065 Registered: Feb-05 | Integra makes decent HT receivers with better than average service records (and they actually sound pretty good). http://www.integrahometheater.com/ |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9788 Registered: May-04 | . "The stuff just should not break. It never used to." ROTFL! Thanks, I needed that. |
Gold Member Username: NuckPost Number: 5904 Registered: Dec-04 | k |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 4092 Registered: Feb-05 | I think Jan has some feelings related to the Pioneer stuff or perhaps the mass marketed gear in general....ya think. |
