Noise and popping sounds coming from speaker.
Username: Davidhue
Post Number: 10
hi ,just wondering if this means my amp is faulty:i have a month old marantz pm7200 ki int.amp ,and i am getting a crackling, popping and then eventually humming noise through one of my channels (other speaker channel is fine).have narrowed it down and can eliminate speakers and speaker cable as source of prob. which just leaves my practically new superb marantz amp.does this mean it is indeed faulty or can something else be the cause of this interference?
thanks.
Username: Artk
Albany, Oregon USA
Post Number: 4043
It's probably a cold solder joint and needs to be taken in for service. Stop using it as it can damage your speakers.
Username: My_rantz
Australia
Post Number: 1161
Maybe Ken Ishiwata shoulda kept his hands off it lol! Sorry to make light of your situation, but Art has got it nailed. At least it's under warranty being almost new.
Username: Davidhue
Post Number: 11
ok, thanks for the advice. i know what you mean m.r. i upgraded from the pm7200 and never had any probs ever.i'll try and get it sorted out.
thanks again.
