New reciever on the cheap?
Username: Skeletonrobot
hey, im in the market for a new reciever. i just need something basic and decent in the $200-$400 range. i need something with a phono input so i can listen to punk records, and i would like something pretty decent that i can upgrade around. thanks for the help!
Username: Artk
Albany, Oregon USA
Post Number: 4020
HK 3380 by Harman Kardon.
http://www.harmankardon.com/product_detail.aspx?Region=USA&Country=US&Language=E NG&cat=REC&prod=HK%203380&sType=C
keep in mind that the price on the manufacturers website does not reflect what you can buy this for. You can get it for much less.
For a little more bread...in fact out of your stated budget you could get the Outlaw RR2150. Better receiver with an excellent phono stage. It can only be had internet direct from the manufacturer and the price on the website is indeed what you'd pay.
http://www.outlawaudio.com/products/rr2150.html
Happy hunting!
the outlaw does sort of look like exactly what im looking for, but really is out of my price range. i love the usb jack and mp3 player integration.
okay, i jumped the gun. the harman kardon looks 100% like what i need. thanks a ton!
Username: Arande2
400dB could probably d..., SouthWest Mi... Too Many DBs...
Post Number: 1146
Gun Jumper!!!
Username: Mrtomasulo
Post Number: 95
Get a refurbished HK on ebay directly from HK (they are a frequent ebay seller). Way cheap.
Username: Artk
Albany, Oregon USA
Post Number: 4021
Happy listening!
is it worth the scratch for the 3480's 120v over the 80v's of the 3380?
Username: Artk
Albany, Oregon USA
Post Number: 4022
There you have it.
Post Number: 97
Dave, check your pm.
Username: Mvanmeter
KY USA
Post Number: 95
HK refurbished equipment direct from HK...
www.harmonaudio.com EXCEPT their site is down at the moment, all HK sights are down
i got a refurb on ebay for just over 160. should be here by monday! thanks for the input everybody.
Username: Nuck
Post Number: 5886
Which unit Dave?
Username: Gamerdude
Ontario Canada
Post Number: 402
H/K 145
Username: Gamerdude
Ontario Canada
Post Number: 403
Nvm i forgot you wanted phono
