Newbie Question...Need Sub Help!!!
Username: Jserlan
Peoria, Illinois United States
I'm a 19 year old college student just beginning to take an interest in home theater and audio..I was wondering..I have subwoofers for my car, is there any way those can hook up to a receiver or anything for use indoors? Like I said I'm new so if this is a completely stupid question I'm sorry but all the help I could get would be appreciated!!!
Username: Project6
Post Number: 12824
Of course you can, but you have to consider whether or not your receiver or home amp can handle them.
Username: Jserlan
OK, my subs are not too powerful I would say, at least in comparison to other car subs. I think they are about 225 W RMS, but I'm sure this might be too much for my Sony Receiver. I can see right on the front of the receiver it says 100W x 7, do you think this could work?
Username: Project6
Post Number: 12826
Speakers don't have watts.
Anyway, what you need to worry about would be the impedance handling of your receiver. If you are using car subs, they will typically be 4 ohms and cheap home receivers cannot typically handle a 4 ohm load. The usually go, pfft!
Username: Thecrypt
Lawrence, Kansas
Post Number: 140
Unless you hook the subs up to equal 8 ohms (man you learn so much when you put together audio systems in cars)
Username: Jserlan
What would I be looking to spend for a good receiver that could handle those?
Username: Jserlan
Or how would I go about making the subs equal 8 ohms? Like I said total newb so sorry for the annoyance!!
Username: Project6
Post Number: 12830
If you are using 2 - 4 ohm subs you'd want to connect them in series.
Or you can check out parts express.com and get a BASH amp. You can get one for less than $200 and I believe it can handle a 4 ohm load. You then build the amp into your sub enclosure.
Username: Stefanom
Vienna, VA United States
Post Number: 363
Dare I ask what you have against using a subwoofer made for home use?
Username: Nuck
Post Number: 5784
SM, Jeff is a college student.
Kraft dinner and chicken weiners.
Ahh, the old days.
Notice I ommited 'good'.
Username: Project6
Post Number: 12833
The "good ol' days"...hah!
Times when you are bad, young and usually about nights!
Username: Jserlan
Stephen, I have nothing against a subwoofer designed for home use at all. The thing is, like the other guys pointed out, I'm a little short on funds at this point in my life and I already have the car subs. Plus, while I'm at school I don't have my car with me, so I figure why not try and get some use out of those subs? Basically my interests are for music purposes, I love music with some nice bass to it, so I was just trying to see what I could incorporate with what I already have.
Username: Stefanom
Post Number: 364
My opinion would be to sell the car subs and obtain something for home use. I'm not saying to spend thousands of dollars or anything, but I'd imagine that something on the order of a Dayton sub or two would do the job quite nicely for a very reasonable price. Not to mention the job of calculating a good enclosure size, port measurements, etc are done for you.
Username: Nuck
Post Number: 5789
Jeff, thats good advise.
Username: Project6
Post Number: 12840
What brand subs are they?
Username: Jserlan
I have 2-12 inch MTX Thunder 4500's
Username: Project6
Post Number: 12841
Sell them. Use the money to buy a home sub.
Username: Artk
Albany, Oregon USA
Post Number: 3940
Yep.
Username: Davidpa
Portland, Oregon US
Post Number: 374
And Yep.
