Silver Member Username: Uback007Post Number: 136 Registered: Mar-06 | I am wanting to upgrade my Paradigm Titans V.4 a step-up - maximum I want to spend is $650. My set-up consists of a Cambridge Audio 640A V.1 Integrated, Cambridge Audio 540D dvd player, Anti-cable speaker cables, and Signal Cable interconnects. Any suggestion as to some speakers to check out would be much appreciated. |
Bronze Member Username: ByamPost Number: 26 Registered: May-06 | Look on Audiogon for a pair of used Paradigm Studio 20 v.3's. I had a pair of Studio 40 v.3's and was happy with them. I see there are currently two pair listed for your budget. You are already familiar with the Paradigm sound. I think you will find the Studio series a definite upgrade from your Titans. |
Gold Member Username: NuckPost Number: 5861 Registered: Dec-04 | Uback, the v3's are history with the v4's out now. You might score a pair of demo'd froma dealer broken in and priced well. They are very nice. Plus stands. |
Gold Member Username: T_bomb25Dayton, Ohio United States Post Number: 1508 Registered: Jun-05 | You may want to look into the Onix Reference 1 on sale right now for $599 here is there site www.av123.com |
