Bronze Member Username: Unreal_tUnited States Post Number: 61 Registered: Feb-06 | What is the difference between a stereo integrated map such as this http://www.rotel.com/products/integrated-amplifiers.htm and a stereo power amp such as this http://www.rotel.com/products/specs/rb1050.htm and a stereo pre amp such as this http://www.rotel.com/products/stereo-pre-amplifiers.htm what would be the amp to get for regular 2 channel musical listening. |
Bronze Member Username: Jingka99Kuala Lumpur, Kuala Lumpur Malaysia Post Number: 73 Registered: Aug-06 | Integrated Amp means a 1 box solution with both Pre-amplifier and power amplifier... The combination of stereo power amplifier + stereo pre-amplifier = separates, meaning there are two separate components... The pre-amp is where your sources(CD player, tuner, etc.) are connected...The pre-amp is then connected to the power amp which is in turn has the connections to your speakers... |
Bronze Member Username: Jingka99Kuala Lumpur, Kuala Lumpur Malaysia Post Number: 74 Registered: Aug-06 | oh and to answer your question, it depends actually, you can go either way, with the integrateds or with separates...but normally, the separates will mean more $$$... And also, you have to provide more info such as your listening area which will define how much power you will need, your type of music which will define which type integrated or separates will suit your needs(in terms of manufacturer, as each manufacturer has it's own house sound)...these two info will also help you define the speakers you need... And lastly, the most important one, is your budget.... |
