Looking for Speaker-Subwoofer Package for Small Office
Username: Stoofpilot
Looking for reasonable quality small size speaker and subwoofer combination. Only need two speakers. Willing to spend $200-400 dollars.
Any suggestions?
Thanks
Username: Gavdawg
Post Number: 205
These are a little larger than the typical micro speaker, but should fit your needs quite well. They give a rundown as to the reasons they feel the typical "micro" speakers really are not all they are cracked up to be.
http://www.htd.com/Middy-Compact-Speaker?sc=7&category=6
A subwoofer will be needed, but with the speakers priced at $75 each, a subwoofer will be easily affordable with your budget. HTD also has subwoofers listed on the website for sale.
This combination is more than your budget, but the sound quality will be outstanding.
Orb Audio Model 1 stereo speakers and HSU Research STF-1 subwoofer. I have heard the Orb speakers, and the sound quality is fantastic, far better than something this small has a right to sound.
The Orb speakers are $219, and the subwoofer is $250.
http://www.orbaudio.com/index.asp?PageAction=VIEWPROD&ProdID=6
http://www.hsuresearch.com/products/stf-1.html
Another option would be the Cambridge Soundworks Ensemble 208 speaker package. It packages two of the MC200 sats with their BassCube 8S subwoofer.
http://www.cambridgesoundworks.com/store/category.cgi?category=spk_subsat%26item %3Dk1pk208zz
if I think of anything else, I will come back and post it.
