Bronze Member Username: AkiraotomoPost Number: 38 Registered: Jan-07 | Okay so i have 6 bose speakers(various sizes and rnages) and now I need a sub. i am a dj, specifically drum and bass, so i need something with low frequency response, thats explosive. i have about 400 dollars to spend... heres my system I have 2 of each Bose 201 Series IV, Bose model 100j, Bose 301 series III... This is the room that its going in.. http://flickr.com/photos/dank/370624309/in/photostream/ *yeah i know the center needs to go next* uive been looking at the buttkicker LFE because it seems to have high wattage and low frequency..but i want somthing thats gonna sound real good too... |
Bronze Member Username: AkiraotomoPost Number: 39 Registered: Jan-07 | http://flickr.com/photo_zoom.gne?id=370624309&context=photostream&size=o |
Silver Member Username: GavdawgPost Number: 195 Registered: Nov-06 | you gave a bad link in the range of $400, I would recommend taking a look at the following two companies: HSU www.hsuresearch.com SVS www.svsubwoofers.com http://www.hsuresearch.com/products/stf-2.html http://www.hsuresearch.com/products/vtf-1.html http://www.svsound.com/products-sub-box-10nsd.cfm those are the 3 subwoofers that come to my mind as of right now |
Platinum Member Username: Project6Post Number: 12735 Registered: Dec-03 | Are you going to use the sub for your gigs or just home? If they are for gigs, you need to look at professional speakers. |
Gold Member Username: NuckPost Number: 5702 Registered: Dec-04 | Excuse me, but you are a DJ with that crap? Kid, you gotta upgrade the whole shite. Large. |
Silver Member Username: GavdawgPost Number: 204 Registered: Nov-06 | The subs that I mentioned were for home use only. |
Gold Member Username: NuckPost Number: 5707 Registered: Dec-04 | Matt had better be joking. |
Bronze Member Username: AkiraotomoPost Number: 40 Registered: Jan-07 | Nuck, the sound in here is very sufficient for what I do, When i play shows, sound is provided, I dunno where you're from or your status as a dj but for me, thats a given. oh and the whole shite? When it comes to other equipment my stuff is tip top....do some research because you obviously dot know what your looking at.. I have two technic 1200mk5, with shure white labels, ultrasone dj pro 1 headphone, along with serato scratch live, denon mixer, denon reciever, m-audio trigger finger, and a E-mu 25 key xboard. i rock ableton, reason, fruity loops, and along with scrach live*obviously*. sit on it brosef, it only hurts for a minute. |
Bronze Member Username: AkiraotomoPost Number: 41 Registered: Jan-07 | "Nuck, the sound in here is very sufficient for what I do," minus the woofer. P.s. I have a 7 month old boy, i really have no need to ruin his hearing. |
Bronze Member Username: AkiraotomoPost Number: 42 Registered: Jan-07 | one last thing in my defense, what i have now is a helluva lot better than what I had...i promise you...it was an embarassment |
Gold Member Username: NuckPost Number: 5710 Registered: Dec-04 | If it sufficient for what you do, minus the sub, then good for you. |
