New old amp and pre
Username: Nuck
Post Number: 5640
So I have the 1973 Pioneer now, it needs a cleaning. I have nonresidual contact cleaner to hose it down.
What a beauty. The pre has bass and treble for each channel, low and high bypass filters and norm/revertse(180 deg) selector.
This thing has what would be a HT 5 yrs ago built in, but STEREO!
Now, the Q.
Both units have 20g lamp cord for power, non grounded.
What should I use for power cord?
I have 14g cap-tie(rubber shrouded 3-wire), should I use something else?
I will solder on the stuff I have to try it out after the cleaning, but is there a better rec?
Username: Jan_b_vigne
Dallas, TX
Post Number: 9697
Why do you think you have to change the power cables?
Username: Nuck
Post Number: 5656
20g cables, 30 yrs old.
Lamp cord.
Dallas, TX
Post Number: 9701
Is the insulation in good shape? Any signs of deterioration on the cable or plug?
Username: Nuck
Post Number: 5688
A bit frayed at a long term bend in the cable.
Like arond a corner for 20 yrs or so.
Username: Nuck
Post Number: 5699
Well the pre will not power up at all, and the ingress to the power connections are via 30 year old Reed and Prince screws, covered in shite.
I may have to cut the screws with the Dremmel, losing the original screws in the process.
Yeehaw. Not.
Dallas, TX
Post Number: 9706
Nuck, you need to let your wife decide which power tools will be required. Just hope she doesn't choose her new chainsaw.
Username: Nuck
Post Number: 5701
Jan, if you could skate, I AM a defensman.
Username: Nuck
Post Number: 5755
I met up with a local guy today, via my BIL.
This mechanic/garage owner guy is a Pioneer lunatic.
He has stacks 6' tall.
Spec4 amps(3), Spec 1 preamp, dual 26 band EQ's.
4 tape decks,want a mint PT 2150 deck? $300CDN.
Manual bias, manual tape set, 5 zillion buttons, a nice studio.
2 sets of speaks, stacked(it ain't a great listening room), HPM700 and HPM900. He has a set of 100's upstairs, but needs a woofer.
And his buddy has 5x more than that!
Who says Canadians can't have rednecks!?
