SDAT 8" Subwoofer
Username: Brettw
Hi,
First post, sorry if it is a repeat.
But what is the story with the SDAT 8" sub?
I just read a VERY long post on the SDAT 404 speaker, so I'm now inclined to believe that this unit may be OK, not great , but OK.
Trying to stay low priced, but willing to spend more if I get a much better product.
thanks,
Brett W
All comments are appreciated
Username: Gavdawg
Post Number: 100
SDAT may not be the best bet. MartinLogan had the Dynamo on closeout at Magnolia for $300 of $399, which is a steal for this subwoofer. It is truly a great performer, especially for that price.
Username: Nuck
Post Number: 5572
The white van is shopping subs now?
Username: Brettw
didn't see the van, it may have been repainted to almost any neutral color.
Fact is I'm torn between a cheap new sub, older (maybe good) used JBL 12" sub and the Martin Logan if I could find it for 400 and not the 600 Best Buy sells it for.
Username: Nuck
Post Number: 5577
Try what you want, brett, I would shoot for the ML.
I have zero experience with SDAT, just the buzz on the forums that say white van.
It may be covered in shelfpaper.
Quick getaway.
Username: Joe_c
Atlanta, GA USA
Post Number: 1328
I love JBL but their subs suck,
I would go for the ML or maybe HSU or SVS if you can deal with not hearing it first.
Find a Jamo D4SUB and have your own slice of heaven would be choice number one hee hee
Username: Artk
Albany, Oregon USA
Post Number: 3862
If Magnolia still has the ML Dynamo in silver you can get it for less than $400.
