New member Username: TeroperPost Number: 1 Registered: Jan-07 | Just got CS505-4, at first i was very pleased with it but quite soon i noticed that there is quite annoying problem with some records. My CS505-4 stops playing far too soon before ending grooves so i can't play my records all the way end. This is a problem especially with the 7" single records where audio grooves goes very close to record label. Does anyone know is there any way how to adjust point where auto switch off activates? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9664 Registered: May-04 | . https://www.ecoustics.com/electronics/forum/home-audio/315944.html |
New member Username: TeroperPost Number: 2 Registered: Jan-07 | I contacted my dealer and they promised to change it to new one or alternatively pay costs of adjusting auto switch off to point where it plays records all the way end. Just wondering on which option i should choose. What is normal point where auto switch off activates? My turntable lifts tonearm approx. 5,8 centimeters from the center of the record. Is this normal procedure for the Dual turntable? In this case i should definitively take the second option where dealer pays the costs of adjusting it. |
