Bookshelf choice
Username: Malco49
Baltimore, Maryland Usa
Post Number: 47
currently use PSB image B25's w/cambridge 540A
cambridge 640C v2 and pro-ject debut lll with
audioquest interconnects
am thinking of upgrading speakers to either
the PSB stratus monitor or the paradigm studio 20 v3 or v4
was wondering on any thoughts on these possible choices.
thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 9662
Why those three? What's wrong with what you already own?
Username: Jingka99
Kuala Lumpur, Kuala Lumpur Malaysia
Post Number: 66
Agree with Jan, what is the reason you want to upgrade? Anything that you'd want to hear that is not present in your current setup?
Mitchell, people here in ecoustics normally gave recommendations/suggestions with reference to the overall system you have, it is very seldom that they compare products alone such as those speakers you mentioned.
Username: Malco49
Post Number: 48
ok point taken
what do you think of my system as it stands.
and would the two previously referenced speakers add any
overall sonic improvement?
or what speakers would provide synergy with the system i have.
would also consider other speakers.
jan-nothing per say is wrong with my speakers was just wondering if upgrading would make any noticeable diffrence.
Dallas, TX
Post Number: 9668
If it ain't broke, don't fix it.
Speakers sound different from each other. You're going to have to tell us what you think would be an improvement. If you just want something different, then buy different speakers. If you don't and your present system sounds OK, don't spend money just because you have some to spend.
Username: Exerciseguy
Brooklyn, NY USA
Post Number: 838
Not bad advice Jan.
I've been juggling & auditioning various mid-fi equipment for about 2-years, and I finally have an objective in my sights, it's taken me this long to determine what I like.
Username: Malco49
Post Number: 49
hey you guys THANKS again for "grounding" me a bit.
i am enjoying my system as it stands!
everything sounds smooth great seperation of insturments nice soundstange mids and bass.vocals present and upfront when needed.
the new cd player(cambridge 640C v2)seems to make a huge difference.and if breaking components in matters well it is not even close yet!probably only about 20 hours in.
the PSB's image B25's are here for a bit.
(just got caught up in the crazy need for more more more....thanks again)
Username: Nuck
Post Number: 5560
Mitch, a nice set of cables might make you even happier!
Username: Malco49
Post Number: 50
thanks nuck
i currently use audioquest sidewinder for CDP to amp
and decent speaker wire(see one of my previous posts on this thread)
Username: Nuck
Post Number: 5576
Very good.
Sorry I missed the other post.
Username: Joe_c
Atlanta, GA USA
Post Number: 1332
There is no cure for upgradeitis... I have had it for a long time now.
