New member Username: Emerson1Post Number: 6 Registered: Jan-07 | I have a Samsung ht-q100 and I can't find anywhere to adjust the sound settings. I am not getting much bass out of the sub and I want to raise it, and from what I am seeing there is no knobs. I looked at the menu and couldn't find anything. I might just be missing a menu. any suggestions? |
Gold Member Username: NuckPost Number: 5446 Registered: Dec-04 | Kyle, post your receiver/amp and the settings. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9644 Registered: May-04 | . If you can find no knobs on your subwoofer, there probably aren't any. The sub is likely meant to run off a specific system and the system will determine the amount of bass sent to the sub. Is this a home theater in a box type system? |
New member Username: Emerson1Post Number: 7 Registered: Jan-07 | http://www.bestbuy.com/site/olspage.jsp?skuId=7711185&st=samsung+2.1&type=produc t&id=1138086437442 That is the system I have. |
Gold Member Username: NuckPost Number: 5456 Registered: Dec-04 | What you hear is what you get, Kyle. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9648 Registered: May-04 | . Put the sub on the floor in a corner. |
Gold Member Username: NuckPost Number: 5465 Registered: Dec-04 | With 18" or so between all sides. |
