We don't want to overspend on speaker wires. FOr the rear speakers we have 30 ft each. Shall I go iwth 14, 16 or 18 wires? (not sure what they are, but the salesman told me about them)
gauge is the diameter of the copper wire, the smaller the number, the bigger the wire, and don't ask, I did not invent the system... 8-}.
Anyway, good 14 gauge "zip-cord" or even 16 gauge, will work fine. Some zip cord (very similar to 2 wire lamp cord) has nickel plating on one conductor, natural copper for the other, but all zip cord has one of the wires marked with a raised rib on the outer covering or a printed line. This helps you hook them up red to red, black to black from the receiver to the speaker. Although they will work if you cross the wires, you could get the speakers out of phase and the sound will not be as good.
Zip cord is available at all Lowes and Home Depots, and most hardware stores and is much less expensive than the audio store "speaker cable"
~~ Monster wires are very expensive, about $60-70, while other brands with the same length like Philips and Omega are about $10-15. I didn't see the gauge written on Monster and the salesman didn't know what is! Shall I go for the Philips regardless of the price difference?
Sara, the Phillips are fine. You do not need banana connectors. The battery thing is just to make sure you have the wires the right way, I am sure you will do that. You will be fine, as soon as you put some Elvis on, for Nuck and Martin!
