Is there a difference between harman Kardon avr 320 and avr 325???
Ian
I was wondering if there is a difference between these two models. I was also wondering if the avr320 is a good receiver to buy???
GT
If you plan to use 7.1 I'd recommend the 325, because although the 320 does 7.1, you have to add an external amp for the last 2 channels. If you're sure you'll only want 5.1, with no expansion in the future then get the 320, especially if it's significantly cheaper.
325 has more crossover bass management features and is the newer/current model.
I have the 320 and love it but if I could have purchased the 325 for say $100 more I would have gone that way.
