Rti 10
Username: Llsht14
Post Number: 14
Give me your take on the polk rti 10 towers
Username: Project6
Post Number: 12457
Have you listened to them?
The important thing is YOUR take on them. You will be living with that decision and whether people like it or not is irrelevant.
Username: Joe_c
Atlanta, GA USA
Post Number: 1300
I liked them even though the bass was a little muddy.
Username: Arande2
400dB could probably d..., SouthWest Mi... Too Many DBs...
Post Number: 832
Nate didn't you say those were arriving soon at your house? Are you going to keep the JBL's or replace them with these?
Username: Nuck
Post Number: 5317
They seemed OK to me.
Keep them away from corners.
And the rear wall.
Username: Llsht14
Post Number: 15
im replacing the jbl tlx 181's with these
Username: Praetorian
Post Number: 451
While I hate to argue with Nuck, mine are about a foot away from the wall (and one in a corner) and I love them. No regrets at all except maybe since I have a subwoofer I only needed the 6's. However, I have no issues with the base both reinforced or not either, but maybe I am easy to please...
Username: Nuck
Post Number: 5505
MC, don't hate to argue with my 2c, that's what makes this thing work!
If you only needed the 6's with a good sub, were thay just too good a deal to turn down?
I liked the Rti10's for their transiants.
A very smooth transition for the mid/high's.
The muddy bass was the reason for my speaker positioning suggestion.
